Saltar al contenido principal
2008 Volvo S40 Low Beam Headlight Replacement
  1. 2008 Volvo S40 Low Beam Headlight Replacement, Low Beam Headlight: paso 1, imagen 1 de 3 2008 Volvo S40 Low Beam Headlight Replacement, Low Beam Headlight: paso 1, imagen 2 de 3 2008 Volvo S40 Low Beam Headlight Replacement, Low Beam Headlight: paso 1, imagen 3 de 3
    • Open the hood of the car and locate the silver locking pin.
    • Gently grasp the top of the pin and pull it directly up until it is completely removed from the engine bay.
  2. 2008 Volvo S40 Low Beam Headlight Replacement: paso 2, imagen 1 de 2 2008 Volvo S40 Low Beam Headlight Replacement: paso 2, imagen 2 de 2
    • Place one hand on the front of the headlight and the other behind it.
    • Gently rock the headlight back and forth until it starts to detach from the car.
  3. 2008 Volvo S40 Low Beam Headlight Replacement: paso 3, imagen 1 de 3 2008 Volvo S40 Low Beam Headlight Replacement: paso 3, imagen 2 de 3 2008 Volvo S40 Low Beam Headlight Replacement: paso 3, imagen 3 de 3
    • Gently pull the two metal retainers away from each other.
    • Remove the plastic housing that protects the bulb.
  4. 2008 Volvo S40 Low Beam Headlight Replacement: paso 4, imagen 1 de 2 2008 Volvo S40 Low Beam Headlight Replacement: paso 4, imagen 2 de 2
    • Disconnect the wiring harness by pushing down on the middle of the two clips while wiggling each piece away from each other.
  5. 2008 Volvo S40 Low Beam Headlight Replacement: paso 5, imagen 1 de 3 2008 Volvo S40 Low Beam Headlight Replacement: paso 5, imagen 2 de 3 2008 Volvo S40 Low Beam Headlight Replacement: paso 5, imagen 3 de 3
    • Pull the low beam bulb out of its socket by gently grasping the black plastic knob and rotating 90 degrees counter-clockwise.
  6. 2008 Volvo S40 Low Beam Headlight Replacement: paso 6, imagen 1 de 3 2008 Volvo S40 Low Beam Headlight Replacement: paso 6, imagen 2 de 3 2008 Volvo S40 Low Beam Headlight Replacement: paso 6, imagen 3 de 3
    • Lock in the new bulb by rotating it 90 degrees clockwise.
    • Push the two clips back together to reconnect the wiring harness.
    • If at any point the rubber gasket from the bulb housing was removed, make sure that it is fitted back into the grooves before the housing is replaced.
  7. 2008 Volvo S40 Low Beam Headlight Replacement: paso 7, imagen 1 de 3 2008 Volvo S40 Low Beam Headlight Replacement: paso 7, imagen 2 de 3 2008 Volvo S40 Low Beam Headlight Replacement: paso 7, imagen 3 de 3
    • Push the back of the headlight housing back into place.
    • Push the two metal retainers towards each other to lock it.
    • Line up the indent on the headlight with the opening on the housing and gently push the headlight completely into place.
  8. 2008 Volvo S40 Low Beam Headlight Replacement: paso 8, imagen 1 de 3 2008 Volvo S40 Low Beam Headlight Replacement: paso 8, imagen 2 de 3 2008 Volvo S40 Low Beam Headlight Replacement: paso 8, imagen 3 de 3
    • Completely push the headlight all the way into its housing until it is flush with the car frame.
    • Push the headlight locking pin back into place, minding the holes in which it must be threaded through.
    • Close the hood and insert the key into the ignition. Turn the lights on.
Linea de Meta
Jake Bass
Miembro Desde 07/08/23
157 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 55
Todo El Tiempo: 445
