Saltar al contenido principal
1975-1983 BMW 3 Series Taillight Disassembly
Qué necesitas
  1. 1975-1983 BMW 3 Series Taillight Disassembly, Taillight: paso 1, imagen 1 de 1
    • This is the best guide to disassembling your BMW E21's taillights to replace a bulb.
  2. 1975-1983 BMW 3 Series Taillight Disassembly: paso 2, imagen 1 de 3 1975-1983 BMW 3 Series Taillight Disassembly: paso 2, imagen 2 de 3 1975-1983 BMW 3 Series Taillight Disassembly: paso 2, imagen 3 de 3
    • Remove the two plastic nuts holding the taillight lens in the housing.
    • I recommend putting a towel in the trunk/boot so the plastic nuts do not get lost under the carpet.
  3. 1975-1983 BMW 3 Series Taillight Disassembly: paso 3, imagen 1 de 2 1975-1983 BMW 3 Series Taillight Disassembly: paso 3, imagen 2 de 2
    • Pull the taillight lens out of the housing.
    • Be sure to use both hands to remove the lens instead of one hand, especially if your taillight lens is cracked. (If you try to remove the lens while using one hand, the lens may get stuck on the screw stud and snap off.
  4. 1975-1983 BMW 3 Series Taillight Disassembly: paso 4, imagen 1 de 1
    • Remove the light bulb by pushing into the housing on the bulb gently, and then unscrewing it and pulling it out.
    • Do not grip the bulb too hard, it may break!
  5. 1975-1983 BMW 3 Series Taillight Disassembly, After the replacement: paso 5, imagen 1 de 1
    • The bulb now functions as intended. Good job!!
Conclusión
Una persona más ha completado esta guía.
Vintage_Restorations
Miembro Desde 07/30/23
191 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 35
Todo El Tiempo: 195
