Battery
1 Respuesta 1 Puntaje |
Why is my device not holding a charge? |
What do I do when my LEDs don't light up? |
Herramientas
Estas son algunas de las herramientas comunes que se utilizaron para trabajar en este dispositivo. Es posible que no necesites todas las herramientas para cada procedimiento.
Background
The Fosera Scandle is a solar device created for providing energy and lighting. Fosera has been creating innovative solar technologies since its founding in 2011. According to Fosera, the Scandle uses LEDs with a luminescence rating compared to 15-35 Watt incandescent light bulbs while only using a fraction of the power. The unit can be connected in series with other Fosera products, such as the external hanging lantern which can be used to light open areas or the Fosera Radio. The energy stored in the on-board battery can also be used to power various mobile devices using the included power adapters. This unit can be easily mounted to provide ongoing use in a particular location. It is very user-friendly and will provide years of use.
Identification
The Fosera Scandle 200 differs from its 25/75 counterparts in respect to luminescence and storage capacity. Overall, all three units resemble each other closely. You will have to reference the packaging in order to identify which model you have, as there is not a model number printed on the device. A box should be filled in on the original packaging which states which model is included.
Technical Specifications
System Voltage - 3.25V
Capacity - 1400mAh
Luminescence - 140- 160lm
Hours of Operation - 4/70hrs (Bright/Dim)
